quick question about resetting the IAC.
Old Apr 28, 2010 | 07:38 PM
87TAGTA66's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7 TPI
Axle/Gears: Stock 3.23's
it says on a tech article after replacing it has to reset and you have to manually reset the idle to 450 then the ECM will automatically reset itself to 600 RPM but it doesnt say whether you set the idle while its in park or drive. thanks for any help
Old Apr 28, 2010 | 09:21 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: quick question about resetting the IAC.
Park or neutral
Old Apr 28, 2010 | 09:36 PM
87TAGTA66's Avatar
Engine: 5.7 TPI
Thanks for the quick response!!! So what should I be idling at if it's running right? Right now it runs around 850 rpm in gear and between 1100 and 1300 rpm in park I always thought that seemed a little high
Old Apr 28, 2010 | 10:07 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
The technical article you refer to says when you set idle at 450 with IAC unplugged, then it should be around 600 in drive and now plugged back in. That's what mine did, but that was in neutral since I have a 5speed. So I figure 600 in Drive and a little higher in neutral makes yours sound a bit too high. Really not an expert, I just read and followed the directions in that section.
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
