Another Timing question
Old Apr 29, 2010 | 01:40 AM
8587ta's Avatar
Car: '91 Firebird
Engine: 468 BBC w/ 8-71 blower
Transmission: Th400
Axle/Gears: 9-bolt 2.77
Ok, I know how to use a timing light and set the timing. But why does my car run perfect when it is WAY off from the timing mark (we're talking 3 inches away when the light flashes) and runs like crap when set with in the area of the timing marker?
Old Apr 29, 2010 | 02:04 AM
windowrattler's Avatar
Car: 92 RS, 89 Formula, 84 Iroc
Engine: Carb 350, TPI 305, TBD
Transmission: T-5, 700r4, TBD
Axle/Gears: 3.42 Posi, 3.08 Posi, Moser 3.73
Re: Another Timing question
There are two or three different types of harmonic balancers and timing marks. There is 12 o'clock and 3 o'clock. If the keyway slot and timing mark on the balancer are almost aligned with each other then you need a "normal" pre-87ish 3 o'clock postion timing marker. If the keyway slot and timing mark are about 40 degree apart then you need an 87+ timing tab with zero straight up. If one is wrong you can see that you'll be around 30-40 degrees off from where you think you are.
Old Apr 30, 2010 | 01:54 AM
8587ta's Avatar
Car: '91 Firebird
Transmission: Th400
Thanks that would make sense, I have no idea who built this engine but I am on a quest to know exactly what every part is that I have.
Old Apr 30, 2010 | 02:56 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Are you disconnecting the EST wire first ?
Old Apr 30, 2010 | 03:00 AM
8587ta's Avatar
Car: '91 Firebird
Transmission: Th400
Yes I am disconnecting the EST wire first, but when I set it to where it lines up with the marker and I reconnect the wire it stays there only until I turn the car off. When I start it back up it is back to where it was set originally.
Old Apr 30, 2010 | 08:13 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
That doesn't make any sense.
You set the initial with the EST unplugged. When you plug the EST in, then the ECM will add a lot of timing - should be immediate.
When you unplug the EST again you should see your initial timing right where you just set it.
Are you sure you have the correct wire? and are following the procedure correctly?
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
