compression difference from stock 64cc heads to 58cc afr
Old May 2, 2010 | 10:41 PM
johnny89345's Avatar
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
im tring to get a base idea of how many points each cc in the combustion chamber and compression ratios go to help pick me out heads for my car. i know stock are 64cc and im looking at afr 195s but they have a 58cc combustion chamber. so what would each compression be thanks guys
Old May 2, 2010 | 10:45 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: compression difference from stock 64cc heads to 58cc afr
On a typical SBC, a fairly accurate rule of thumb is that each cc is worth about 0.10:1. So if you have 10.2:1 at 64 cc, then swap to 58cc using the same head gaskets, you should be around 10.8:1. And this is about as accurate if we replace the 10s with 9s. 9.2:1 to 9.8:1
It's not exact, but it is safe enough.
theshackle
Mar 5, 2017 06:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
