loosing coolant
Old May 16, 2010 | 09:44 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Axle/Gears: 9 bolt posi 3:27
loosing coolant
but i have no idea were at. there is no evidence of coolant on the dipstick or oil filler cap and the car only smokes on initial start up. after it warms up no smoke. floor is dry and the heater core was just replaced a little bit ago. i do notice a little bit of a sweet smell when i turn my heater on though. car is an 87 trans am with a rebuilt 350 carbed
Old May 16, 2010 | 11:44 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: loosing coolant
Warm the engine then pull a valve cover and check the underside. If you have a white foam, your coolant is making its way into the oil (most likely from a bad head gasket). Checking the dipstick wont always tell you since the coolant is heaver than oil and sinks to the bottom of the pan.
Old May 17, 2010 | 12:32 AM
johnny89345's Avatar
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
Re: loosing coolant
if you really smell coolant in the car chack the hoses that go to the heater core they can be leaking be may not be coming in the car. if there are no streaks from the coolant over there you are burning it. in some cases there are no visible signs of any burning or leaking.
Old May 17, 2010 | 11:52 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
Re: loosing coolant
pull a valve cover. see whats on the bottom side
Old May 18, 2010 | 12:21 AM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: loosing coolant
my advice to you is ... start tearing stuff apart at the heater core and check there... go all the way taking everything you need to take apart as if you were going to remove it... if you are smelling the coolant that means there's a leak.... there aren't more than a probable of 2 areas where you would get a coolant smell from...
Old May 18, 2010 | 01:26 AM
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
Re: loosing coolant
pressure test it budd. go to pepboys, they have a radiator cap looking thing with a pump on it, pump it up till you find your self a leak.
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
