steel shim gaskets..
Old May 21, 2010 | 12:35 AM
sparkplug619's Avatar
Car: 1990 RS Camaro
Engine: 305 TBI
Transmission: T-5 stick
Im trying to raise compression from 9.1:1 to 9.5:1. I found a gasket that'll tke me to my goal almost perfectly.
http://www.summitracing.com/parts/FEL-7733SH1/
After I ordered them from autozone ($2 cheaper) I started to look into steel shim gaskets and found out they blow easily.
If I clean up my block and head good enough and use plenty of copper spray, will these gaskets last on a cam'd daily driver?
The engine is an lo5 that looked to be in very good condition from the tear down.
Old May 21, 2010 | 12:37 AM
Car: 1990 RS Camaro
Engine: 305 TBI
Re: steel shim gaskets..
Im also using brand new head bolts FWIW
Old May 21, 2010 | 12:46 AM
jackel200269's Avatar
Car: 92 camaro
Engine: lo3 v8
Axle/Gears: 10 bolt posi 4.10
Man thats risky, Can I ask why you are willing to give up reliability for a half a point of compression? You wont even notice the tiny bit of power you'll gain.
Old May 21, 2010 | 12:50 AM
Car: 1990 RS Camaro
Engine: 305 TBI
I was in the market for a new head gasket anyway since I tore the engine down. I didnt know the risk of steel shim gaskets until after I ordered it.
I was just wondering if it'll hold up since I see alot of people running them from hotrodders.com to people from various forums
Old May 21, 2010 | 12:54 AM
Car: 1990 RS Camaro
Engine: 305 TBI
besides, all the other gaskets I see either lower compression into the high 8's or are way out of my budget. Im talking $80 each
Old May 21, 2010 | 01:04 AM
Car: 92 camaro
Engine: lo3 v8
You could try them, worst that will happen is they dont seal and fill you cylinders with water which in turn destroys you engine by hydrolocking. Had a friend run those all copper jobbers and they leaked and his rod wound up on the outside of his block. I know gaskts get but spendy but the head gasket is no where to cheap out. Id put MLS gaskets in her and never look back.
Old May 21, 2010 | 01:16 AM
Car: 1990 RS Camaro
Engine: 305 TBI
well I have till the 22nd for the refund so Im going to take a look around, if I cant find anything good enough compression wise, Ill copper these things up and try my luck.
I see millions of mixed reviews about these head gaskets but most of them are in favor of them if you clean up good.
Old May 21, 2010 | 01:23 AM
Car: 92 camaro
Engine: lo3 v8
Please keep us informed. The more we all know the better.
Old May 21, 2010 | 01:26 AM
Car: 1990 RS Camaro
Engine: 305 TBI
BTW, I have a set of felpro blues that came with a gasket kit but calculating my compression with these drops me down to 8.8:1. I really couldnt live with that
Old May 21, 2010 | 01:33 AM
Car: 92 camaro
Engine: lo3 v8
Lol why not 9.5 is the max you should run on a iron headed street engine, you can go higher but it takes a big cam to get it done. 8.8:1 is not bad for a street car. I bet you wouldn't loose 10hp, and if you do all the rest you would still have way more power than you do now.
Old May 21, 2010 | 01:39 AM
Car: 92 camaro
Engine: lo3 v8
Sorry got myself all crossed up between two posts.
Old May 21, 2010 | 01:40 AM
Car: 1990 RS Camaro
Engine: 305 TBI
I am also camming it before reassembly, with all new valvetrain. my cam will have .479/.480 lift. I am trying to squeeze as much power as I can out of just this tear down and cam because im not going to have any money to build up the car after this for a while
Old May 21, 2010 | 01:45 AM
Car: 92 camaro
Engine: lo3 v8
I understand completely.
Old May 21, 2010 | 01:49 AM
Pat Hall's Avatar
If you want just a little more insurance against the possibility of the thinner gasket leaking, you ought to buy a pair of Fel-Pro 1094's. They're a steel shim gasket, but they have a thin rubber coating on them. Compressed thickness is only .015" and they're only 22 bucks a piece from Summit.http://www.summitracing.com/parts/FPP-1094/ Or you could use the GM Perfomance Parts '117 gasket and I guarantee it'll seal with them. The GMPP gasket is composition and only .028" compressed thickness. They're only 20 bucks a piece. I used the GMPP gaskets for the AFR aluminum heads on my new 355 and they worked out great. http://www.summitracing.com/parts/NAL-10105117/
Old May 21, 2010 | 02:01 AM
Car: 1990 RS Camaro
Engine: 305 TBI
Ah, the 1094's. I was looking at these but somehow passed them up.
How much more insurance would the rubber coating give me?
Old May 21, 2010 | 02:20 AM
Car: 1990 RS Camaro
Engine: 305 TBI
I think Im going to stick with the head gasket I have for 8.8:1 compression but if I can squeaze some change out Im going to cut down my heads for a little more compression. I want to at least have 9.0:1+ compression
Old May 21, 2010 | 02:45 AM
Pat Hall's Avatar
Oh yeah, hands down the best/safest way to bump up your compression would be milling the heads. As for the rubber coating on the 1094's, it'd definitely help compared to bare steel gaskets, especially when you're re-assembling block and heads that haven't been newly decked and milled.
Old May 21, 2010 | 03:00 AM
Car: 1990 RS Camaro
Engine: 305 TBI
better safe then sorry. Im gonna get my money back for the gaskets and find out how much itll cost to mill the heads. I remember getting quoted between $25-$50 when searching for a place for my supra heads.
BTW, how low can I take the heads down safely?
Old May 21, 2010 | 03:18 AM
Car: 92 camaro
Engine: lo3 v8
If I remember right you can cut .040 off before you have to address the intake.
Old May 21, 2010 | 03:31 AM
Pat Hall's Avatar
If you can find a GOOD machine shop where they actually know SBC's well, they should be able to tell you how far you can mill them. You have to be more careful with the newer SBC heads when it comes to how far you can safely mill them. Just about all factory SBC heads from the mid-70's on up are lightweight castings, so they're more prone to cracking if they're milled too much. The old-school heads from the 50's and 60's were a lot heavier casting, so you could mill a bunch off them. But yeah, if you get them milled down a bit and use the .028" GMPP gaskets, you could bump up your compression quite nicely. Btw, what casting number are the heads you're using?
Old May 21, 2010 | 04:05 AM
Car: 1990 RS Camaro
Engine: 305 TBI
This is embarrassing, 193.
Old May 21, 2010 | 06:25 AM
game1939's Avatar
Car: 91 chevy camaro
Engine: 383
Transmission: 700r4 built with corvette servo
Axle/Gears: posi 3:73
Old May 21, 2010 | 08:14 AM
Pat Hall's Avatar
No worries, that's what I figured they'd be on a L05 motor. Since those are common as dirt, why not mill them some and see what happens? At least you won't feel like you ruined a killer set of expensive racing heads if something goes wrong with the milling experiment! Lol.
Old May 21, 2010 | 09:20 AM
Car: 1990 RS Camaro
Engine: 305 TBI
Ya, the heads arent going to stay but it'll be awhile before I end up replacing them so im going to play around with them.
From a calculator, I can achieve 10.0:1 compression, using the recommended gmpp head gasket, and milling .030.
I am going to find a reputable machinist and tell him to mill as much as possible, but i'd be very happy if I can get away with .030
Old May 21, 2010 | 09:22 AM
Car: 1990 RS Camaro
Engine: 305 TBI
Im pretty sure 10.0:1 on 91 octane will do me plenty good
Old May 21, 2010 | 09:55 AM
Car: 1990 RS Camaro
Engine: 305 TBI
BTW, I got my refund for the steel shims this morning
3rdgenparts
May 21, 2016 11:50 PM
darwinprice
17
Oct 11, 2015 11:51 PM
skinny z
Oct 5, 2015 06:23 PM
gord327
Oct 3, 2015 01:25 PM
meeklay812
Oct 1, 2015 03:46 PM
