Just picked up another '87 sport coupe
Old May 21, 2010 | 05:31 PM
chcgobearsfan3's Avatar
Car: 90 camaro RS
Question, if it's dated as being manufactured in 08/87, will it have a big chance of being roller?
Second, I'm debating on an engine swap or a blower with a 6" cowl or fixing up the 305.. (I'm looking to run mid 13s, nothing special)
Pros for blower: The heads I have are 081s, and I'm thinking that in combination with 7 psi from a weiand 142 the results should be decent..close to that of a 350 with a mild cam. I'm not sure what size the primaries and collector should be with blower, same with the back piping.
Cons: I don't think the Q-Jet would work? Might with a new chip but I don't know..
Swap: My other option would be to put in a 350 short block with 081s, and the rest of the stuff off the 305. Headers would be easier to pick and so would the cat back.
Cons: I think it'd be more expensive to build the engine or have it built and installed.
305 Pros: It's already in, heads are decent for 300 hp without spinning it to the moon. This would be a lot cheaper, saving money for things like aluminum water pump, and other minor adjustments to the suspension and trans. Any idea on a cam that would put me around 275 rwhp? Also, does the engine have to be lifted to install a cam? I've never done it myself.
Cons: 305
So out of the three, which would be most cost/power effective and put me into the 13s. I'm not looking to build a super car, just something that'll run pretty quick times and have gears near 2.73 for mileage. As of now, I've done nothing but pick up new tires.
Old May 21, 2010 | 05:37 PM
game1939's Avatar
Car: 91 chevy camaro
Engine: 383
Transmission: 700r4 built with corvette servo
Axle/Gears: posi 3:73
Re: Just picked up another '87 sport coupe
go with the 350, better yet get you a 350 and 383 it......... Knowing what i know now, no more stock 350 for me........ 383=tourque monster...... cheap to build, reliable, and yes i drive mine EVERYDAY!!!!!!! read my profile and look at me motor specs......
Old May 21, 2010 | 05:40 PM
game1939's Avatar
Engine: 383
no lift nessassary on cam install, take out radiater condenser and center supoort bracket
Old May 21, 2010 | 05:41 PM
Car: 90 camaro RS
I've heard the 383s need to be rebuilt quite often, having to drive 100+ miles a day, I need something reliable, unless what I've heard is wrong.
Old May 21, 2010 | 05:51 PM
Car: 90 camaro RS
That's good news for me, haha. Okay, let me change up what I want a bit.. a mid-high 13 second car with around 300 hp that will be able to keep the 2.73 in back as I do a ton of highway driving at 75 mph+. Easiest way to do this? Now it seems like the blower would be the best..or the 350, since the 305 falls short in torque
Old May 21, 2010 | 06:44 PM
game1939's Avatar
Engine: 383
thats crazy, its justa 350 with a 400 crank, build good run good last long time, my last one 300,000+ miles and was still runnig. the people saying that nonsense either A: bought cheap chinese kit. or B: not having the knowagle to handle the task. or c: all the above.....I drive mine everyday no problems whatsoever, i would drive across country and not think twice about it.....
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
TP355Z
Exterior Parts Wanted
Oct 21, 2015 01:05 AM
Night rider327
Oct 9, 2015 09:25 AM
FueledSoul
Sep 30, 2015 09:18 PM
Night rider327
Sep 25, 2015 04:47 AM
