roller cams better then flat tappet?
Old May 23, 2010 | 04:23 PM
my84camaro's Avatar
are roller cams better then flat tapet cams?my camaro is going to be all street.I have a chance to get a 84 350 cheap and as wondering how the roller and flat tappet cams compare to each other.
Old May 23, 2010 | 05:48 PM
HF_monster's Avatar
Car: 86' z28 (died 5/1/11) 76 k10 pickup
Transmission: th350
Axle/Gears: 3.73 open
Re: roller cams better then flat tappet?
yes roller cams are better less friction and all faster opening rate blah blah. but they are going to cost you way more than a flat tappet. the block that you listed will not be set up for a roller cam so you will have to get a retro kit and they still cost alot. if your willing to spend the extra cash then go for it other wise look for a block already set up to run a roller cam it will be alot cheaper.
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
