which rear end should i buy
Old May 24, 2010 | 10:50 PM
johnny89345's Avatar
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
i just bought the adapeters for the z06 rims for the front and want to buy a rear from a 4th gen for the upgrade in brakes and so i donot need to use adapters. which rear should i get 93-97 camaro rear or the 98-02 camaro rear.
Old May 25, 2010 | 01:03 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: which rear end should i buy
98-02 because they have better brakes than 93-97.
Old May 25, 2010 | 08:04 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
That's exactly what I was gonna type.
Old May 26, 2010 | 12:50 AM
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
if i buy a complete rear disc to disc with e brake cables will i need anything else
Old May 26, 2010 | 01:07 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Time....its a direct bolt in.
Old May 26, 2010 | 02:13 AM
you'll need to fab a bracket for the e brake cables if you want to use them. also remember that your rear brakes can only be as good as the front. if you have 12" brakes on the rear and 10" on the front the car will stop no better.
Old May 26, 2010 | 01:01 PM
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
o i realize that im going to do the ls1 brakes in the front and i alreadty have an adjustable prop valve
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
