New Cam...Help...
Old May 25, 2010 | 05:45 PM
83C_CamAroZ28's Avatar
Car: 1983 Z-28
Engine: 5.7 L
New Cam...Help...
ok i bought this cam for my 350 COMP 12-210-2 and i was told i was goin to need new lifters new springs and rockers and a new timin chain...
any idea wat lifters and rockers and springs i can put on?...
part number will help...i just need sumthin good but not the expensive...just not cheap ether...
help plz and thanks...
Old May 25, 2010 | 05:54 PM
8t4marinator's Avatar
Car: 1984 Camaro Z28
Engine: 305 H.O. L69
Axle/Gears: 7.5" 3.73
Re: New Cam...Help...
Why don't you give these a try: SUM-174001 for valve springs, they support up to .490 lift.
Old May 25, 2010 | 05:58 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
NO! Instead, check these out:
http://www.competitionproducts.com/H...uctinfo/98111/
I've used them with the Z4 cam and 1.6/1.52 I/E rockers to 5500 rpm without issue. And they're far less money. Plus they don't come from China.
Old May 25, 2010 | 06:31 PM
Car: 1983 Z-28
Engine: 5.7 L
ok thanks...when ordering the springs do they just come in a pair or the whole set?......wat about the lifters and rockers?...
Old May 25, 2010 | 06:43 PM
CanuckBird's Avatar
Car: 83 Z28
Engine: 355
Axle/Gears: 3:73
Jegs has a sale on their stamped steel roller rockers right now. Part # 555-20180 for $79.99.
Old May 25, 2010 | 07:12 PM
Car: 1983 Z-28
Engine: 5.7 L
o ok thanks...wat about lifters anybody?...does it matter which one i put on?...does it matter if i put Hydraulic Lifters or Hydraulic Roller Lifters
Old May 25, 2010 | 07:20 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
you must not put roller lifters on that non-roller cam. you must use new lifters, and in this case, the American made lifters really are better than the Chinese imports. Spending a bit more here really is worth it.
Old May 25, 2010 | 07:56 PM
Car: 1983 Z-28
Engine: 5.7 L
ok...so dont use the roller lifters...so just put any regular lifters that r made for a 350?...do i use roller rockers or non roller rockers?...wat ratio?..
Old May 25, 2010 | 07:59 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
stock rockers are fine. If you want to upgrade, do it after you've broken in the cam and lifters.
Old May 25, 2010 | 09:28 PM
Car: 1983 Z-28
Engine: 5.7 L
ok den thanks...wat about the lifters?...any regular lifters made for a 350 r fine?...or nah?...let me kno plz...pullin out engine this weekend...
Old May 25, 2010 | 09:42 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
If you dont have a roller cam, use "Hydraulic Lifters", I assume you dont have a solid lifter cam.
Yes, for a 350 SBC.
Old May 25, 2010 | 10:00 PM
Car: 1983 Z-28
Engine: 5.7 L
no i have a Hyd Flat Tappet cam...
Old May 26, 2010 | 01:17 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
You want hydraulic flat tappet lifters.
Old May 26, 2010 | 10:07 AM
Car: 1983 Z-28
Engine: 5.7 L
ok then thanks 4 the help guys...
