Timing for 88 Camaro 350
Old May 25, 2010 | 07:52 PM
mrkling's Avatar
Can someone tell me what the correct timing is for a 88 stock Iroc 350. Thanks
Old May 25, 2010 | 08:18 PM
BahN's Avatar
Car: 1987 Trans AM
Engine: Twin Turbo 6.0 LS2
Re: Timing for 88 Camaro 350
Assuming TPI:
NOTE: I DID NOT WRITE THIS, 1TPI DID! (just easier copying :P)
NOTE2: TPI's are generally 6* BTDC
Things you will need:
You MUST definitely use a timing light to adjust your timing correctly. You definitely CAN'T do this correctly just by turning your distributor and guessing.
If you just guess when you retard the timing so far that you can't hear any pings doesn't mean anything. Most of the time you won't be able to hear any ping/knock, but your knock sensor will.
The only way a timing adjustment does make sense is: Adjust it using a timing light and hook up a scanner/winaldl and check for knock counts under all driving conditions. If the engine does knock/ping, retard it in 2* increments.
A 9/16" or 14mm open end wrench.
To adjust your timing:
Warm up your engine to normal operating temperature. Shut off your engine.
Disconnect the tan wire with a black stripe that comes out of the harness near the heater box. It is a big weatherpack connector, you can hardly overlook it.
Connect your timing light to the battery (check polarity), connect the inductive pickup of the timing light to your #1 cylinder as near to the spark plug as possible without toasting it with your exhaust manifold/header.
Start your engine and ignore the SES light coming up.
Point your light at the timing mark and check your setting. Watch the timing light's wires. If they come in contact with the drive belt/accessories while the engine is running you could get seeriously injured.
If you can't read your timing mark because of rust/dirt, stop your engine and clean it using sanding paper (PITA).
If you still can't read what's on your timing mark: Assuming you are standing in front of your car, facing the engine, the "valley" of the biggest of the v-shaped notches should be zero degrees.
The Vs are upside down when you look at them from the front of the car.
The next peak (pointing towards you) to the left of the big V is 4* advanced, one more peak to the left is 6* and so on in 2* increments.
Accordingly, the one and only peak to the right of the big V is 2* retarded.
Check for the sticker in your engine compartment for the correct setting and compare it to your reading. If it matches you are fine.
Proceed with step 10.
If it does not match or you want to advance/retard your timing for other reasons get a 9/16" or 14mm open end wrench and proceed with the next step.
Remove your air cleaner and approach your engine from the driver's side. Locate the distributor hold-down clamp and screw.
Insert your wrench in the opening between the ignition coil and the distributor from the driver's side.
Loosen the distributor hold-down clamp just so much, that you can turn your distributor by hand with little effort (Should be a 1/4 to 1/2 turn of the screw, maybe a little more). There my be several other ways to loosen the distributor clamp but this one worked for me. Maybe you can find an easier way, using other tools.
Now point your timing light at the timing mark again and rotate your distributor slighty.
Turning it counterclockwise advances the ignition, turning it clockwise retards it.
If you have your setting as desired, tighten the distributor hold-down clamp.
Recheck your setting after that.
When it is still fine, shut off your engine, reconnect the tan wire, disconnect your timing light and disconnect the negative battery cable for a few minutes. This will erase the error code that came up when you disconnected the tan wire.
Reinstall your air cleaner and reconnect your negative battery cable.
Test drive your car using a scanner or to check for pings/knocks.
Old May 28, 2010 | 05:42 PM
rs89todd's Avatar
Car: 1986 Chevrolet Camaro
Engine: 355 chevy
Transmission: t-5
Axle/Gears: 3.73 disc brakes
how different is that from a carb and hei? im trying to get my 305 going but my dist got spun and had to reinstall and i dont think im anywhere close, my grandpa can "appearantly" do it by ear, but its back fired more than anything, should i trade in grandpa for a timing light? i dont think we have one availble
but we started setting the timing mark on the harmonic damper and set the distrib to number one and the vacum advance is just before by breather i should really take a picture but i think the timing is going too early when the intake valve is open...holley is getting rebuilt but took gpas qjet carb off his 305 camaro to get it running
Old May 28, 2010 | 06:46 PM
BahN's Avatar
Car: 1987 Trans AM
If you're running an HEI, you need to disconnect the flat 4-wire connector on the back of the dizzy. Trade in grandpa for a timing light (just get the cheapest one). Adjust it to 0*.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Sep 17, 2020 08:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
camaro71633
Sep 1, 2015 10:24 AM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
