Car won't restart after getting up to running temp.
Old May 26, 2010 | 03:28 PM
xpsmoto's Avatar
Car: 1989 GTA
Axle/Gears: 3:27
89 gta 350 tpi starts fine then after it has run and is up to operating temp (195) will not start (just cranks) until car cools for 20-30 minutes, fuel pump runs when key is turned on, Any Ideas?
Old May 27, 2010 | 03:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Have you checked spark and fuel pressure when it won't start?
Old May 27, 2010 | 03:29 PM
xpsmoto's Avatar
Car: 1989 GTA
Axle/Gears: 3:27
Re: Car won't restart after getting up to running temp.
No I have not, But i did some more testing last night and it is more intermitent than I thought, it seems if I tap the maf sensor enough it will start but not always, I didn't have any problems until I cleaned the maf sensor with maf cleaner last year , should I try cleaning it again? also I did not have any problems until I installed headers, also
I checked the vacumn line to the fuel pressure reg, no gas in it.
Old May 27, 2010 | 03:33 PM
racethesunlive's Avatar
Car: '92 Camaro
I had a similar problem where I'd get spark but no start after the engine warmed up. I replaced the Ignition Module and never had a problem since. So thats what I'd try, good luck!
specialized
Jun 18, 2022 09:26 AM
midge54
Dec 27, 2019 04:14 PM
TheExaminer
Aug 26, 2015 04:59 PM
justin57
Aug 20, 2015 07:05 PM
kyleb24
Aug 15, 2015 08:24 AM
