Ignition upgrade on 305 4bbl Z28
Old May 27, 2010 | 03:39 PM
Cammy85's Avatar
Car: 1985 Z28 in Silver
Engine: 302(4bbl)
Transmission: Stock auto
Axle/Gears: Stock
Hi guys
I've recently ordered some new parts from the States for the Camaro. Most of which are ignition system overhaul: new plugs(ACCEL U-groove shorties), Taylor Pro leads, ACCEL distributor(top coil mount) and new rotor. The plugs I have now are Champion plugs and they are a bit sooted from the very short journeys that I do on the weekends and the 8mm Splitfire leads have a few splits in them.
The distributor has an ACCEL HEI coil pack fitted and I was wondering could I get away with incresing the electrode spark gap over stock to take advantage of the improved ignition voltage or should I stick to standard plug gaps?
Cheers
Cammy85
Old May 27, 2010 | 03:40 PM
Cammy85's Avatar
Engine: 302(4bbl)
Axle/Gears: Stock
Re: Ignition upgrade on 305 4bbl Z28
p.s how much gap could I go up to???
Old May 27, 2010 | 05:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
.045" gap should be fine. You can try more in .005" increments to see if it makes a difference.
Old May 29, 2010 | 09:55 AM
Cammy85's Avatar
Engine: 302(4bbl)
Axle/Gears: Stock
Cheers fella-maybe the stock 0.45 gap would be fine if I'm running U-Grooves as they're supposed to give a bigger spark kernel.
Jake_92RS
Jan 28, 2020 10:37 PM
Fast355
Dec 2, 2016 06:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
