so I bought a 307.....
Old May 27, 2010 | 09:42 PM
ymenic's Avatar
Car: 1982 Camaro z-28
Engine: 307
Transmission: th-350 with stage 2 shift kit
Axle/Gears: stock
I bought and 307 with a th350 out of a 78 el camino but the motor and tranny was from a 72 nova. I checked it all out no air bubbles in radiator, no blow-by in either valve cover. I took the driver side valve cover off to get the head number and it all seems fine. The motor had a lot of power, tranny wasn't slipping, no carbon built up on the inside the motor, the oil was black no anti freeze, and no smoke at all. Okay, I was putting it in my car and I open up the passenger side valve cover and at the top it was all filled with water/oil, milky look. There was also a little oil/water on the head but not that much maybe a two nickles size. I was putting the water pump on today and it was raining like hell. I think I got some water in the engine today,the oil now is milky looking. I was just wondering what you guys think? Do a oil change and hope for the best? I also hook up a vacuum gauge and it looked perfected steady needle.
Old May 27, 2010 | 09:48 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: so I bought a 307.....
Seems like all you can do is change the oil and hope.
But I believe it would take more than a little rain to turn the oil milky.
Old May 27, 2010 | 09:52 PM
grassyflats's Avatar
the bad could be a cracked cylinder head
the good would be condensation
Old May 27, 2010 | 09:56 PM
ymenic's Avatar
Engine: 307
Axle/Gears: stock
Yea that's what I thought but when I was driving that El Camino I check the oil twice and it was black no milky in it at all. Now that I remember I had a water hose that goes into the intake manifold didn't have the hose clamp on it so it was leak pretty good. The water was on top of the intake and valve cover maybe the valve cover gasket is bad and water leaking into through the valve cover / head. The water in the radiator was still clear. I'll do oil change on Monday and I'll see if it fixes the problem.
Old May 27, 2010 | 09:58 PM
ymenic's Avatar
Engine: 307
Axle/Gears: stock
The whole valve cover on top was completely filled with milky oil. You think one year will cause that, oh on that side is where the PCV is.
Old May 28, 2010 | 11:37 AM
zraffz's Avatar
Car: 1987 Camaro
Engine: LQ9
Axle/Gears: 4.10
That little 307 with an airgap intake, holley 600 cfm carb and 100 shot of nitrous will put that camaro into the low 13's.
GTAman
Jul 3, 2024 07:29 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
pimprs
Aug 24, 2015 11:20 PM
