92 z28 distribtuor
Old May 29, 2010 | 10:42 AM
92z28rockinmaro's Avatar
92 z28 distribtuor
hey everyone i need to know where to face the distributor of my z28... i forgot the way to put it back in... does anyone have a installation step? i need to know wwhat way to face it
thanks
Old May 29, 2010 | 02:58 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Re: 92 z28 distribtuor
Installing it calls for a bit more than just which way if faces.
You need to have the #1 piston near TDC ON THE COMPRESSION STROKE, then the rotor tip needs to be pointed at the #1 cap terminal.
Then the oil pump drive rod has to be indexed with the distributor otherwise the distributor won't drop all the way flush with the intake manifold.
Hopefully someone has detailed step-by-step instructions they can post or point you to. If not, I'll have to type one up for you. It's not all that difficult but does call for a few steps.
Check Shoebox's site; he may have the instructions posted there.
Jake
starliner
Feb 9, 2016 08:18 PM
blackz281le
Jan 11, 2016 07:51 AM
David Frans
Oct 31, 2015 08:12 PM
Night rider327
Oct 9, 2015 09:25 AM
z28joe2
Sep 28, 2015 05:54 PM
