slight ticking
Old Jun 1, 2010 | 01:08 AM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Axle/Gears: 9 bolt posi 3:27
slight ticking
so i have hydraulic lifters and the ticking wasnt there before i changed my oil a few hundred miles ago. its only present when im going up hills or around 2000 rpms. the oil pressure is good and there is no exhaust leak i tightened all the header bolts and i still here it. added some resilone to the engine on the advice of an older gentleman and this seemed to help a bit. the last oil change i did i used full synthetic and the gentleman said i should have used regular oil and added a quart of zdp cause my engine is a flat tappet hydraulic cam. could the full syn be my problem?
Old Jun 1, 2010 | 01:15 AM
jay173's Avatar
Re: slight ticking
might just need a valve adjustment unless the oil you used is affecting lifter pump up
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
gord327
Sep 29, 2015 10:18 PM
mfp189
Sep 27, 2015 09:25 AM
