new jersey
Car: 1987 camaro,88 firebird
Engine: 2.8 v6,5.0 tpi
Transmission: manual
Axle/Gears: 3.47
new jersey
who wants to come down and fix my camaro lol. help a brotha out. ive been wanting to drive this thing so bad.. but im broke lol. timing needs to be completely redone .. distributor. not the chain.i tried putting it in and it wont start.. i give up
Car: 1987 Camaro
Engine: LQ9
Axle/Gears: 4.10
Re: new jersey
ah you're too far away for me to help... maybe when I go to the shore I can stop by.
when the distributor was out, did you try and start the car? If not and the timing was previously set properly, you can put the distributor in the other way and it should be set... you probably have it 180 degrees backwards.
Axle/Gears: 3.47
Re: new jersey
nah. it was in right i believe . i had it running like a month ago for like a day.. but i just found out it has a stretched timing chain.. waiting for the funds to fix it.. thank you guys for making an effort to reply
Axle/Gears: 3.47
Re: new jersey
and also when i bought the car the distributor was loose. which means it was fooled with. i had a buddy come by and found top dead center and we put it in n it popped out the tail pipe so we 180'd it. so i know its in the right spot.. and i didnt try and start it with the distributor out.
Street Lethal
Apr 30, 2019 12:14 PM
Hill1513
Sep 19, 2015 04:15 PM
twiztidz28
Apr 12, 2002 11:06 AM
