Are these goal realistic?
Old Jun 7, 2010 | 09:33 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
I am thinking about building a bigger motor down the road. I want to plan every last single part before buying anything so I want to make sure my plan is even realistic. If it is doable, I may buy a part here and there when I find a really good deal on it. Mainly the block.
I want to build a 434. I want it to be able to rev to 8000 but make max power around 7500. Yes it will be in a mainly street car, but I like high rpm power over tons of torque. I have thought about road racing too. The car will have AC as well. It needs to idle in Central Florida summer heat and not overheat.
The block would be a 2 bolt main splayed to 4 bolt.
For heads I'm sure AFR 220's would be the best. Would my Canfield 195's ported out to the max by a pro with the bigger 2.08 intake valve be decent enough?
I may keep the car carbed or I may go fuel injected. If carbed, it would be a 950 cfm. If fuel injected, it would be a EFI victor jr.
I am looking for 650+ HP NA. Is a stock block able to hold this? Like I said, I wouldnt be building this for a while. I just want to make sure 650+ NA horse power on a stock splayed 4 bolt main block is possible and not have it overheat.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
ZZ3Astro
Aug 13, 2019 12:57 AM
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
Nick McCardle
Sep 10, 2015 08:36 PM
