Air idle valve?
Old Jun 10, 2010 | 03:27 PM
Alinton's Avatar
Car: '87 Camaro
Transmission: 5-speed manual
Air idle valve?
Hi all, 305ci TPI.
Is there an air idle valve anywhere?
I need to adjust the stop on the throttle so it doesn't stick, but then of course the tick-over is too high.
Some engines have an air-idle valve that can be adjusted to compensate for this.
Thanks,
Andy
Kilkenny
Ireland.
Old Jun 12, 2010 | 05:04 AM
Alinton's Avatar
Car: '87 Camaro
Re: Air idle valve?
So guys, is there one?
A.
Old Jun 12, 2010 | 08:43 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Air idle valve?
Originally Posted by Alinton
So guys, is there one?.
Is controlled by the computer.
If you change throttle stop position then you need to reset TPS and IAC valve to get idle right
See
http://www.corvetteactioncenter.com/...and+Idle+Speed
Old Jun 12, 2010 | 02:16 PM
Alinton's Avatar
Car: '87 Camaro
Re: Air idle valve?
Excellent, thanks.
A.
specialized
Jun 18, 2022 09:26 AM
mdtoren
Aug 23, 2015 12:52 PM
db057
Aug 22, 2015 08:17 PM
