i recently installed a 91 caprice serpintine system on my camaro with a new 350 the ps pump wont line up with the crank pulley. i pulled system complete except for crank pulley but have tried two different ones .same size anyone have this problem or better yet a solution? thanks
On Probation
If your junkyard is fresh out of Caprices and F-cars, and if they have a good return policy, maybe try crank pulleys from 4.3 S-10, 4.3 Astro, and any '88-up fullsize pickup. There's 3 different pulleys for ya.
All the crank pulley's are the same as far as i know. I mis and match them all the time without any issues.
Are you sure the ps pump pulley is on right.
it does look like the pump pulley has a good size gap from the bracket that would make it set to far forward from crank pulley alignment i try to move pump back if possible thanks for input.
