Sputters when warm
Old Jun 14, 2010 | 06:57 AM
smarshburn's Avatar
Engine: 2.8L V6 Cross-fire fuel injected
Transmission: 4 speed automatic
Sputters when warm
When the car is cold it operates great. After a couple of miles it begins to behave erratically, regardless of throttle position, the car starts shaking and sputtering. I've replaced the fuel pump and sender, 02 sensor, plugs and wires, and TPS as well as the ECM and have not located any VAC leaks. Good pressures at the fuel rail and I am certain that it is not a fuel issue (though I'm sure the injectors are long due for replacement). I believe it to be a mixture problem do to a poor ECM computation from a sensor read somewhere but I can't imagine which one or perhaps a timing issue but I feel that is less likely since it runs perfectly when still cool. FYI, temp gauge never reports anything above 160 - 200 Degrees so I know it's not running hot... any thoughts?
db057
Apr 28, 2019 07:45 AM
HoosierinWA
Oct 7, 2015 10:15 AM
thejimsterz28
Sep 30, 2015 08:52 PM
mfp189
Sep 27, 2015 09:25 AM
amcnellis
Sep 16, 2015 04:16 PM
