fuel pressure question
Old Jun 19, 2010 | 11:41 PM
johnrstuch's Avatar
Car: 89 Trans am GTA
Axle/Gears: not sure
i have an 89 trans am GTA,350 TPI
i was just wondering what should my fuel pressure be,
before i crank up and run, mine is at 65 psi
haynes says 34 to 47 psi.
but i just want to make sure before i put the
runners and plenum on.
thanks
Old Jun 19, 2010 | 11:57 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: fuel pressure question
Normal TPI specs are something like 45psi with the vac line off ( same as key on , not started pressure ) / 39psi at idle with the vac line connected
Old Jun 21, 2010 | 09:01 PM
johnrstuch's Avatar
thanks
when i put vacuum on it ,no change.
so i guess i amj needing a regulator,
right? btw engine is not running yet,
only vacuum was by mouth.
Old Jun 21, 2010 | 09:15 PM
MTXaudioSYSTM's Avatar
Car: 90 formula
Transmission: auto
take the regulator and see if its diaphragm is ripped. if not then it should be fine.
Old Jun 23, 2010 | 01:52 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
[QUOTE=johnrstuch;4586056
only vacuum was by mouth.[/QUOTE]
I wouldn't trust that method. No need to spend $$$ unnecessarily.
Jake
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
