power steering line question
Old Jun 23, 2010 | 05:36 PM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
i cracked the adjuster screw in my power steering box by accident.
i was going to replace the box with a spare i had in my basement.
in the process, while disconnecting the hard lines coming out of the box, i broke a line b/c it was siezed up.
questions:
1) does anyone know where these lines go on my car? does the power steering fluid get cooled?
2) where can i find new lines for my power steering box?
i have a:
1989 Firebird Formula, which was a stock 305 TPI from the factory
Old Jul 1, 2010 | 01:06 PM
bigchief's Avatar
Re: power steering line question
nevermind guys, i found out that i do have somewhat of a cooler. basically my lines come out of the box, and run one big loop under the radiator. i don't know where to get a new loop from, since i broke the end of mine off, so now i'm just going straight from the power steering pump to the box....
Old Jul 2, 2010 | 10:47 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I was just in the parts store earlier this week getting a new pump and lines. I was leaning over the counter and checking out all the return lines and suprisely auto part stores carry the cooler loops under "power steering return line with cooler" $19 at my local store.
Oreily Auto Parts
Powercraft - Return Line Assembly
Part Number: 91959
Old Aug 6, 2010 | 11:33 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
Transmission: HD 700r4 B&M Stage2 SK
is it really worth it to have?
Old Aug 7, 2010 | 07:03 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Humm, I assumed all thirdgen cars were equipped with them.
EDIT: Curious, I did some searching, but I couldn't find a cooler line before 85 (and my 85 IROC has one).
JamesC
Old Aug 7, 2010 | 10:16 AM
Engine: 383 SBC
Not sure how much it actually cools. For my last pump I redid it. I bent the factory cooler lines so the output goes straight up near driver side radiator core. I then used PS return hose to put a B&M Cooler in front of the radiator on a seperate mount. I've read threads on here people say they boil the PS fluid so I figured another cooler might prevent that.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
redmaroz
Aug 16, 2015 11:40 PM
