How to properly replace rear axle with lower gearing
Old Jun 25, 2010 | 05:08 PM
jay173's Avatar
So how low is too low when replacing the rear axle ring and pinion?
Will I run into any issues on my 89 camaro rs 305 with 700r4?
Where can I buy a speedometer gear to match it?
I am just asking because I have replaced one before on a truck and they made a speedogear to go with it.
Old Jun 25, 2010 | 05:13 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Re: How to properly replace rear axle with lower gearing
You need to post in the transmission and drivetrain forum, not the engine forum.
Old Jun 27, 2010 | 08:30 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
It's engine-relevant to ask what gear ratio is right for a pure-stock LO3. The speedo info does belong in the trans sub-forum. The answers are there, because I made the stickies. One on how to figure out what you need, another on how to get what you figured.
For a pure stock LO3, or even with external bolt-ons, a 3.42:1 gear is right, a 3.73:1 gear is too much. Do all the bolt-ons, plus cam and heads, then you might want 3.73:1. But better to just do the bolt ons plus 3.42s, then do a 350.
The best way to get 3.42:1 gearing is to get the complete rear axle assembly from any '90-'92 F-car with the V6 / auto. Then order a PowerTrax conversion-style locker. This way you don't have to worry about preload or backlash, or the stupid crush sleeve, and you get the 28-spline axles, and it's the 7.625" ring gear.
hectre13
Dec 11, 2023 08:14 AM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
draco
Oct 4, 2015 09:25 PM
