coolant leak!
Old Jul 12, 2010 | 02:25 PM
87_TA_GTA's Avatar
Car: 87 T/A GTA
Engine: 5.7L TPI
Axle/Gears: 3.27:1
coolant leak!
there is a decent sized coolant leak on the passenger side of my trans am. the car drives fine, but when i parked it i could hear something sizzling as if it was dripping on to something hot. i got under the car and there was a light steady flow of coolant coming down from between the trans cover and right before the cat on the passenger side.
any help to diagnose the problem would be of great help. thanks.
Old Jul 12, 2010 | 02:46 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: coolant leak!
Possible heater hose leak at firewall.
Old Jul 12, 2010 | 03:52 PM
Doom86's Avatar
Car: '86 Z28, '91 RS
Engine: 305ci, 305ci
Transmission: TH200c (no kidding), TH700r4
Axle/Gears: 2.73, 2.73
Re: coolant leak!
Heater Core.
Check passengers floor matting for moisture.
If you have a coolant valve that diverts coolant based on HVAC settings (no idea what its technical name is) then if you set your HVAC to cold it won't route coolant to the heater core and thus not leak. I'm not sure what year chevy started putting these valves in, it's not in my 86 but it is there on my 91.
Old Jul 12, 2010 | 05:21 PM
87_TA_GTA's Avatar
Car: 87 T/A GTA
Engine: 5.7L TPI
Axle/Gears: 3.27:1
Re: coolant leak!
there is no moisture on the inside of the car at all, which im happy about. ill try the hvac thing. where is the heater core and in/out tubes located on the firewall?
Old Jul 12, 2010 | 07:39 PM
Doom86's Avatar
Re: coolant leak!
passengers side in the firewall. 2 hoses lined up one above the other.
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
aaron7
Sep 30, 2015 09:15 AM
