headlight dimmer help.
Old Jul 14, 2010 | 10:12 PM
t-ray10's Avatar
Car: 1992 Camaro RS, 2012 ZL1 on order
Engine: 5.0 305, 6.2 Liter LSA SC
Transmission: T5, TR6060
Axle/Gears: stock, 3.73
So I had to do some work in the steering column and it ended up that a piece fell out of the column and I cannot find it anywhere. It pushes up against the rod to the headlight dimmer switch to turn on/off the brights. I believe it connects to the turn signal lever or somewhere near it. Does anyone know what it looks like, where I could buy another one, or a little add on piece that I could use to bypass trying to hunt one down. Thanks
Old Jul 15, 2010 | 03:00 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: headlight dimmer help.
Oh god I know what you're talking about, its a little piece of black plastic that has a curved side to contour to the rod and one that sticks into the dimmer switch, its a pain in the butt to put back (I had to use grease to hold it in place) and its gonna be a bigger hassle to find just that part, your best bet would be go to the jy and find a thirdgen, disassemble the column and find that little devil piece, unless you're mcgyver that is
Old Jul 15, 2010 | 06:09 PM
t-ray10's Avatar
all right, thanks alot BluFBdy
Numbah-1
Oct 2, 2015 08:27 AM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
