afr heads with zz4 cam ok with speed density?
Old Jul 15, 2010 | 07:12 AM
rx8camaro's Avatar
just wondering if the afr heads with zz4 cam runs into any problems with the speed density setup (not familiar with speed density at all). is this setup easy on my ecm before i have it tuned. anyone have any suggestions on a good tune shop in the PA area? thanks.
Old Jul 15, 2010 | 07:23 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: afr heads with zz4 cam ok with speed density?
The AFR heads are a great start, but the ZZ4 cam is not a good match to those heads. I'd suggest you call COMP and order a custom cam, with the 3014 intake lobe, and the 3034 exhaust lobe, on a 114 degree lobe separation angle.
Old Jul 15, 2010 | 07:08 PM
Damon's Avatar
The ZZ4 cam is pretty mild. It'll run, probably make more power than the stock parts, but it won't be very close to optimized.
evilstuie
Jan 9, 2020 08:29 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Steve78LT
Feb 24, 2016 12:15 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
86Base
Aug 8, 2015 01:34 PM
