A quick question..
Old Jul 18, 2010 | 12:36 PM
84camaro18's Avatar
Car: 84 Camaro Sports Coupe
Engine: Stock 305
A quick question..
so ive been buying engine parts for a couple of months. well yesterday i started building my engine ( a 71 block) and when i went to install my main caps they all fit except for my rear main one(the oil pump mount).. if i got main caps from a late 80s/one piece rear main will the rear main cap not fit? any fast replies are very nice!
Old Jul 18, 2010 | 02:10 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: A quick question..
If the main caps are not from your exact motor, then you need to take the motor, with the caps, to a machine shop. They will need to either line hone or line bore the motor. Do not do anything untill you do this.
Old Jul 18, 2010 | 09:49 PM
84camaro18's Avatar
Engine: Stock 305
thanks alot built 91, one more question. would it be the bearings that dont line up or is it possible the bolt holts wont line up. because my bolt holes dont line up
Old Jul 19, 2010 | 07:40 AM
built91Z28's Avatar
I just reread the years of the motors and that is your problem. You need older caps. The newer ones will not work. Ecspecially the rear one where the oil pump goes. That one is going to be 100% different between the two motors. You need to find older caps and then take the caps and block to the machine shop.
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
