Noisy fuel pump after 10 miles question
Old Jul 18, 2010 | 02:00 PM
prostock700's Avatar
Car: 1987 formula daily driver
Engine: 5.7 350
Axle/Gears: B/W 3:31 posi
Howdy, have a 87 formula 350, has a newer gm turbo syclone high volume fuel pump, 22lbs injectors and around 36 lbs fuel pressure, live were its hot, pump starts to howl after a few miles put on, repaced fuel lines by tank, see a trap or one way valve by rubber fuel lines under tank, when I hear it howl can smell gas, when the I take the gas cap off, lots of pressure coming out, is this normal? What is the purpose of that trap by fuel line? Thanks
Old Jul 20, 2010 | 12:42 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: Noisy fuel pump after 10 miles question
This isnt the pump, its the pressure relief valve on the side of the tank. The cause is either lack of exhaust heat sheilds near the tank, or a CCP system that isnt working. If the CCP line becomes clogged, or the system otherwise stops functioning, pressure builds up in the tank to the point where teh pressure relief opens, and causes that noise you hear.
Old Jul 20, 2010 | 12:54 AM
Engine: 5.7 350
Thanks, I will look into it, forgot to mention that the engine check light comes on close to when this happens
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
