fuel system trouble shooting/ specifications
Old Jul 19, 2010 | 11:57 PM
JDMZ28's Avatar
Car: 2KGTP
Engine: supercharged 3800 L67
Transmission: 4T65E
Axle/Gears: 2.93
91Z 305 TPI.
symptoms: hard starting when cold, surging during accel from dead stop, barely any power at WOT, positive blms. Very low O2 voltage during WOT.
my diagnosis: fueling. Either pump, filter, FPR or injectors.
Questions: What psi should I have? What volume? Does the FPR come before or after the service port?
Old Jul 21, 2010 | 01:09 AM
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
Re: fuel system trouble shooting/ specifications
anybody?
Old Jul 23, 2010 | 12:50 AM
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
Does anybody at least know what the fuel pressure is suppose to be???
Old Jul 23, 2010 | 05:39 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Fuel pressure spec is 35-40 at idle with vacuum connected, 40-50 on throttle snap or with vacuum disconnected. Check for issues with your MAP sensor TPS, and CTS. MAP should read about 1.5 at idle and 4.5 WOT. TPS should be .5 at idle and 4.5 WOT. CTS should match dash temp gauge. I assume you have a scanner since you know your BLM, look closely at scan data. High BLM means the ECM is trying to compensate for a lean condition.
The FPR is after the service port, just before the return. Your problem may be fuel pressure or pump but more likely fuel management. Check for any intake air leaks. You may also have bad injectors, check resistance, should be 12-16 ohms each. Injectors are devided into two banks. Each bank should test at 3-4 ohms(12-16/4).
bryan623
Mar 22, 2021 06:43 PM
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
backtothe80s
Sep 5, 2015 12:39 AM
