my camaros dont start
Car: 89RS-5.0/88IROC-Z-5.0/92-5.7 z28/v6
Engine: 5.0/5.7/2.8
Transmission: 5 spd in two stock auto in other tw
Axle/Gears: stock
When i turn the key in my 89 rs and 88 rs (some times the iroc-z's) it does start up fine other times it does not do anything, no click, click, click and when it does start to turn over it starts trying to and very slowly turns over if i pump the gas just wondering anybody know what the problem could be?
Car: 1988 Camaro RS
Engine: 355
Transmission: TH-350
Axle/Gears: 4:10
Re: my camaros dont start
if it turns over very slowly or not at all I would think its a battery, starter, or bad connection to one of the two. try using a multimeter to test and see if the battery is at 12+ volts
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Engine: 5.0/5.7/2.8
Axle/Gears: stock
anyone heard of putting a ground to your engine block to your frame for starting issues?
Car: 1992 RS
Engine: Carbed 350
There are supposed to be several grounds.
1) Batt neg to engine block (usually close to alternator or A/C)
2) Batt neg to body (smaller neg cable from batt to fender)
3) Engine block to body (usually from pass side head to firewall)
The engine and the body have to be connected to the neg batt post in order for anything to work. There's no neg cable to the starter, the starter gets it's ground from being attached to the block. Like lights - they have no neg wires either (not all the way to the battery) - they get connected to the body for ground.
Engine: 5.0/5.7/2.8
Axle/Gears: stock
engine block to strut tower any one heard of this idea?
92camaroJoe
Aug 13, 2015 06:07 AM
