***305 Help***
Old Jul 27, 2010 | 07:36 PM
whiteghostrs's Avatar
***305 Help***
besides headers, what would give me the most bang for my buck. I only care about that 0-60 speed but dont have a big budget.
Old Jul 27, 2010 | 08:21 PM
GICATA's Avatar
Car: '83 WS6 T/A 65,000 miles
Engine: 5.0L vin H stock, 406SBC right now
Axle/Gears: Corp. 3.73
Re: ***305 Help***
Need some info as to what the car/engine has now...but gears may help a lot if it's got lazy highway gears.
Old Jul 27, 2010 | 08:49 PM
Convoy25's Avatar
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
Re: ***305 Help***
3.42 or 3.73 gears
along with the headers a good cat back
Old Jul 28, 2010 | 01:51 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: ***305 Help***
It would help to know more info on your car. Year? Transmission Type? Carbed, Fuel injected?
For a budget, it depends on your budget. Hooker 2055 headers (Jet Coated or Ceramic coated if you can afford it), 3" catback. 3.73 gears. You're probably looking at $800 - $1k in cost, including labor if you have someone else do the install. You can probably find used parts on EBAY or here for cheaper than new though so the price really is variable especially if you do your own work.
From here you get into the "other" bolt on mods. This would be a new intake and heads. For a 305, I would recommend the World Products SR Torquers for the 305, or have work done on your stock heads. The key to this is the 1.94" intake valves. Also, have your intake and heads "port matched", also make sure the gaskets are "port matched".
Old Jul 28, 2010 | 06:36 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: ***305 Help***
Been there:
https://www.thirdgen.org/forums/carb...tions-lg4.html
Old Jul 28, 2010 | 08:16 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: ***305 Help***
rear gears, definitely
