Air filter positions/Cold air kits? TPI
Old Aug 4, 2010 | 08:15 PM
HighTechRedneck's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7L TPI
Axle/Gears: Stock 9bolt posi
This is the best place i could find to post this. i was wondering what most people do with air filter positioning on the TPI motors. Also, a question i would like to get answered is do i need to keep the mass airflow sensor on the car. i have seen them with and without, and cant decide what makes the ones with and without different. picture or a good description of your air filter would be cool, looking for some ideas, or better yet if there is a thread already about this, a link would be cool too. thanks
Old Aug 4, 2010 | 10:18 PM
wakeboardr42393's Avatar
Car: 1987 BMW 325is
Engine: M20B25
Transmission: Getrag 260
Axle/Gears: 3.73 LSD
Re: Air filter positions/Cold air kits? TPI
i also have the same question about the mass airflow sensor. i mean i know its supposed to be there but will it run much different without it?
Old Aug 4, 2010 | 10:31 PM
griemar's Avatar
Car: 86' Camaro
Engine: 2.8L V6
your car will run much richer and fuel mileage will goto crap without your mass airflow. I speak from experience. My MAF went out a few weeks ago and I had to wait until my next check to get another one. What used to cost me $30/wk to go back and forth to work turned into $50/wk. As for performance, the car felt very sluggish and would fall on it's face while on the highway.
Old Aug 4, 2010 | 10:37 PM
Engine: 5.7L TPI
at carcraft, i guy told me you need a corvette harness to run with no mass airflow. not positive about that but who knows. i wouldnt try it. i found a ram air design with the stock gta hood online here, i will get those pictures up
Old Aug 4, 2010 | 10:43 PM
Engine: 5.7L TPI
Old Aug 5, 2010 | 09:01 AM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
If your car is equiped with a MAF, then you need to keep it. The cars you are seeing without the MAF are the engines which use Speed Density (SD). SD cars do not have a MAF, they rely on different sensors to calculate airflow. To get rid of your MAF, you'll need an ECM from a SD car.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Zachattack0925
Aug 12, 2015 09:52 PM
