Help! pvc valve and valve covers!
Old Aug 6, 2010 | 08:48 PM
xxpotandaxx's Avatar
Car: 1992 Camaro z28
Engine: 5.0 TPI
Transmission: 5 Speed Manual t5
Ok so i capped the pcv outlet coming from my intake cause i got new valve coevrs with duel breathers My car isent gunna blowup into a million pieces right? and if its wrong hwo can i fix it teh right way
Old Aug 6, 2010 | 08:57 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: Help! pvc valve and valve covers!
You can cap the intake if you have breathers in the valve covers. Thats fine. I use to have 2 breathers, but I went back to a PCV system. Much cleaner if done right. The breathers tend to spray oil on the valve covers.
Old Aug 6, 2010 | 09:03 PM
Engine: 5.0 TPI
Thansk man Your F***ing awesoem you saved me from beogn scared one guy said its gunna make a oil blow by or w.e
Old Aug 6, 2010 | 09:04 PM
built91Z28's Avatar
No problem. You would have problems if you capped the intake and had no breathers. But so long as the blow by has somewhere to go then your ok.
Old Aug 6, 2010 | 09:34 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Because you didn't say in that post that you had installed open breathers on the covers ; only that you had plugged the PCV line.
Correct info helps get correct answers
Old Aug 6, 2010 | 09:40 PM
Engine: 5.0 TPI
i noticed that thats why i reposted it
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
