need help with getting compression
Old Aug 13, 2010 | 08:42 PM
0pyders's Avatar
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
350 engine. I have no compression in the #1 cylinder.
Here's what i have done to it:
-Head swap
-new head gasket (torqued to spec)
-Just got done redoing the valvelash (for the 3rd time...)
-replaced 2 piece rear seal
I understand that If you tighten the nut on the rocker arms too tight then that can be the reason but I even kept them just a little (and I mean little) loose just to be sure that wasn't it. I don't know what else it could be, it ran fine before I messed it up. Tomorrow I'll check the other cylinders to see if there's compression. Anyone got anything I can try?
Old Aug 13, 2010 | 08:57 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Re: need help with getting compression
You've already nailed it; you've set the lifter preload wrong and valve(s) are being held open.
There's a specific procedure you need to follow to get it right. Best one is called the Intake Closing/Exhaust Opening method. There are other methods, but IC/EO is the most often recommended.
Clue: The lifter MUST BE ON THE BASE CIRCLE OF THE CAM LOBE WHEN FINDING ZERO LASH.
I've posted a long, detailed procedure on several Forums on how to it as STICKY'S. It may be here, too - I've just forgotten on how many Forums I posted it.
Jake
Old Aug 13, 2010 | 11:25 PM
ymenic's Avatar
Car: 1982 Camaro z-28
Engine: 307
Transmission: th-350 with stage 2 shift kit
Axle/Gears: stock
Old Aug 15, 2010 | 12:32 AM
0pyders's Avatar
figured it out I had the valves like EIEIEIEI instead of EIIEEIIE stupid stupid stupid
Old Aug 15, 2010 | 11:42 AM
NAASBC355's Avatar
Car: several
Engine: Lots of them
Transmission: also lots of them
Axle/Gears: lots of them
not stupid you learned from it. Now you have more knowlege. Not stupid. You didn't know something, and now you do. No problem
~Couch
FormulasOnly
Jul 23, 2018 08:47 AM
69GTOby
Apr 18, 2016 02:34 PM
Nervous2
Oct 8, 2015 10:53 PM
Jonas Earl
Sep 27, 2015 07:39 AM
WhteRbt
Sep 21, 2015 09:48 AM
