Is it ok to use Dextron III instead of power steering fluid?
Old Aug 15, 2010 | 01:20 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
I want to replace the power steering fluid, and I have tons of DextronIII. I have heard that it can be used in place of power steering fluid, but I thought I would ask some of you gear heads first.
Old Aug 15, 2010 | 11:50 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Is it ok to use Dextron III instead of power steering fluid?
For automotive use, there's usually no problem with using Dexron as PS fluid. (There's no T in Dexron). They're all basically a hydraulic oil with very similar characteristics. Dexron has a red dye added. For many years, it was recommended to use Dexron as PS fluid. Some more modern PS systems require a proper PS fluid but chances are Dexron will still work fine.
Old Aug 16, 2010 | 01:27 AM
No T??? I've been saying that for a long darn timne! Well, both are good to know.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
evilstuie
Apr 14, 2016 08:52 PM
backtothe80s
Sep 5, 2015 12:39 AM
sailtexas186548
Aug 24, 2015 10:11 PM
