power steering bracket without ac
Old Aug 16, 2010 | 01:35 PM
snipe04's Avatar
My a/c was all messed up so i took it all out but in doing so my power steering bracket is not firm. Is there a power steering bracket that does not need the a/c bracket
Old Aug 16, 2010 | 09:58 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: power steering bracket without ac
Not that I know of. Go to my profile and look at my picture albums. I got my bracket there. No biggie having it there really.
Old Aug 17, 2010 | 11:49 AM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
What model, year , and engine size ? More information helps
Old Aug 17, 2010 | 02:19 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Yes, need more info. I'm assuming you have the A/C mount on driver side, and was a v-belt or 1/2 serp 1/2 vbelt setup.
But - the only option I found was March. They are expensive ($100), but I spent way more trying several others that would not work, but the March brackets work well, and I should have not tried to be so cheap myself because I ended up paying more in the end on junk that did not work.
Old Aug 17, 2010 | 11:10 PM
snipe04's Avatar
its a 83 with a 305
Old Aug 18, 2010 | 12:00 AM
Car: 1992 RS
Engine: Carbed 350
So it's a vbelt with A/C on driver side. Like I said, definitely MARCH if looking aftermarket, they are $100, but they work - all the ones I tried that were other brands didn't work at all. March makes several different ones, I would talk to their tech support to find out exactly which you need - the one I got was a 20165, but there are several ones that pretty much look the same, but have different holes in different locarions for different p/s pumps.
There may be other methods (like stock brackets from different years), but I couldn't come up with anything that worked other than the March brackets.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
evilstuie
Apr 14, 2016 08:52 PM
Genopsyde
Nov 11, 2015 10:46 PM
