92 RS aluminum cylinderheads
Old Aug 16, 2010 | 09:47 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Hi guys. I got a question. Could I install a pair of 92 RS aluminum heads on my 350 TPI? Does it really matter if I install aluminum 305 heads on the IROC from a 92 RS?
Old Aug 16, 2010 | 10:44 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: 92 RS aluminum cylinderheads
The 92 RS had terrible swirl port iron heads... No thirdgen had factory aluminum heads, much less a base RS.
Old Aug 18, 2010 | 01:22 AM
Gotcha. Well then the RS that I found at a local junkyard has aftermarket aluminums. But Im not too sure if the heads are for a 305 or 350. Would it be a difference if they happen to be 305 heads? i got a 350. Will I run into engine knock?
Old Aug 18, 2010 | 01:30 AM
Car: 1992 Camaro RS
They're aluminum, so just get them. Post em up and we can identify em for you. They're either GM Corvette L98 heads or they're aftermarket, in any case they're likely worth a good chunk of change if tehy're not cracked/damaged. It'd be worthwhile to have them.
Old Aug 18, 2010 | 01:34 AM
Okay then. The RS just got in the junkyard yesterday. Hopefully theyre (heads) are still there when I get paid on Friday.
Old Aug 27, 2010 | 05:48 PM
No dice. I went on friday and the junkyard guy sold the whole engine.
Linson
Oct 24, 2025 02:00 PM
Royal_Z
Sep 30, 2015 08:45 PM
