Bad engine overheat!
Old Aug 16, 2010 | 11:12 PM
mustangslayer86's Avatar
Car: '88 GTA / '93 Z28
Engine: L98(350) / LT1 (350)
Transmission: 700R4 / 4L60E
I have a 1988 Trans Am GTA that I just reassembled the entire front end. Today I was changing the transmission fluid and the engine began to get hot. I got the transmission fluid to the appropriate level and when I turned off the engine the water/antifreeze mix in the overfill tank was boiling it was so hot. The temperature inside the car still read 100 degrees and the fans didn't come on. However, when I turned the car on a little while ago the fans ran and the temp gauge appeared to work. Am I missing a fuse or do I need what my friend says I need (a new sending unit)?
Let me know what you guys think. I knew it was getting too hot, but he assured me a v8 shouldn't be getting hot that quick. I guess I should go with my own judgement on that from now on since he only owns Hondas. LOL
Old Aug 17, 2010 | 12:06 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Bad engine overheat!
Boiling into the overflow isn't a good sign. The gauge is on a completely different circuit from the CTS and the fan switch, so maybe you have some larger electrical problem?
Old Aug 17, 2010 | 07:42 AM
Would a quick solution be to hook the fans up to a 12 volt toggle? I know I want the temperature and everything to work, but I was hoping to be driving it soon.
If I wanted to fix the problem all together, where should I start? Check the fan wires, make sure everything is hooked up? I searched it high and low to make sure everything was plugged back in after putting the engine back in the car.
Thanks for your help!
89GTAOz
May 16, 2020 09:31 AM
Reddeath210
Oct 6, 2015 08:20 AM
Jae992
Aug 27, 2015 09:07 AM
lakeffect2
Aug 23, 2015 08:44 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
