Vortec Heads on 350 TBI
Car: 85 Trans Am Iroc-Z
Engine: 305 H.O. 4bbl
Transmission: 5 Speed
Axle/Gears: 3:73 Posi-trac
Re: Vortec Heads on 350 TBI
From what I have heard you almost have to redo your whole top end to put vortec heads on.
You might find this article very interesting, I know I did. http://www.chevyhiperformance.com/te...ad_racing.html
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
You'll need a vortec style intake manifold to go with the heads and that's about it. The Vortec intakes have no provisions for the A.I.R. system so you'll have to tap our exhaust if you want to keep emissions. Other than that, it's strait forward. the Vortec style heads are something of a Bottled Geni that GM discovered in the mid-90's as they were the best flowing factory heads GM ever made until some of the newer LS series heads that are out). They'll improve HP and gas mileage in your car.
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
