timing my motor
Old Aug 23, 2010 | 10:10 AM
quick87formula's Avatar
Car: 87 formula
Transmission: 700
Axle/Gears: 12 bolt strange 3.73
timing my motor
i a timing my motor and i have it set at 12 degrees. my stock timing tab only goes to 14 degrees. if i need more timing what should i do. is there a good timing tab i can get. what do you guys do??
Old Aug 23, 2010 | 10:28 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: timing my motor
Use a dial-back timing light, or put a mark on your balancer.
Old Aug 23, 2010 | 10:53 AM
Car: 87 formula
Transmission: 700
Re: timing my motor
i am using the stock timing tab on my cover. how would i mark my balancer??
Old Aug 23, 2010 | 12:06 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: timing my motor
I ordered a timing tape - Mr. Gasket (and several others) make them - it's just tape with timing marks on it, and sticks on the balancer, about $10. You just have to measure which balancer size you have (diameter). Ordered mine through O'Reilly's, but you could order at AutoZone, Advance, Summit, anybody really - just have to find a counter person that knows how to look up performance parts in the books rather than in the computers.
You put the mark on the tape over your balancer mark. Then, when using a regular timing light, you look to see what number on the tape is at 0 on your timing tab - that's what your timing is - works at any rpm, so you can see what your total timing is at any given rpm, and also so you can see at what rpm your total timing is all in by.
Old Aug 23, 2010 | 01:18 PM
Car: 87 formula
Transmission: 700
Re: timing my motor
very cool thanks for the info i will try that first.
Old Aug 23, 2010 | 03:17 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: timing my motor
You don't even need the tape, just measure the number of degrees you want from the TDC mark on the balancer and scribe a mark.
Old Aug 23, 2010 | 04:29 PM
Car: 1992 RS
Engine: Carbed 350
Re: timing my motor
So lets say for example only, that 1/4in equals 4 degrees... if you scribe a line on the balancer 1/4in to the RIGHT of the existing mark (facing engine), then when that scribed mark is reading at 12*BTDC, that is actually 16*BTDC? (the real OEM mark would be slightly LEFT of the timing tab and thus have no reference point since stock timing tab stops at 14)
Do I have the correct thinking here?
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
italiano67
Dec 11, 2016 09:21 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
