I need some help on the valve adjustment thing.
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
Ok so I think I learned that theres 2 kinds of cams, a hydraulic camshaft and a solid camshaft (is that right?). I need to know which type came in the 69-79 350 blocks? because there's one where you tighten an extra 3/4 turn after zero lash and one where you get to zero lash but use a feeler gauge and loosen the nut. I need help please on which one i have
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: I need some help on the valve adjustment thing.
Either type of lifter can be used in any block. You'd have to know the original application, or what it was rebuild with.
so what your saying is that I can use a feeler gauge OR the 3/4 turn?
Engine: 383 Carb
Transmission: 4L60
No, I'm saying you have to know what type of lifters the engine was built with.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
