Hazard mechanicals
Hazard mechanicals
Can anyone help me find a diagram or parts photo that I can blow up to see how the mechanics of the Hazard flasher button works? My turn signals work fine, but when I try to use the flashers ( the button is sloppy loose in the column ) it barely engages and doesn't turn on the hazard lights and then I have to play with it to get it out just right so the turn signals will work again. I have the Bishko CD Shop Manual but it doesn't have a clear enough pic of the info I need. I would really like to have some knowledge of what it looks like and how it works before I go that DEEP into the steering column. Any help would be Greatly Appreciated !!
Car: 91 Camaro RS
Engine: 305 (L03)
Axle/Gears: Stock
Re: Hazard mechanicals
Not what you asked for but hopefully will help you out...
https://www.thirdgen.org/forums/inte...eel-grant.html
Car: 91 Camaro RS
Engine: 305 (L03)
Axle/Gears: Stock
Glad to help. I have a newfound respect for engineers after starting this project. Didn't realize how much work actually goes into designing something until I started doing it! Thanks for checking it out!
sjorgens
Oct 1, 2015 07:54 PM
