Dissy will not go back in
Old Aug 29, 2010 | 02:47 PM
johnson7454's Avatar
I have tried everything in the book. Turned the engine over, turn the engine by hand, tried to align the oil shaft with a screw driver. The only problem i see is that the oil shaft moves from side to side. Therefore the shaft itself never goes into the dissy therefore never allowing me to align the slots. What can i do? Can you pull the oil shaft out? this is on a 305 lb9
Old Aug 29, 2010 | 02:52 PM
BahN's Avatar
Car: 1987 Trans AM
Engine: Twin Turbo 6.0 LS2
Re: Dissy will not go back in
Is this a stock oil pump drive shaft? If so, chances are the little collar that holds it to the oil pump input shaft is broken and not centering it up on the oil pump input shaft. Or your drive gear may have too much play in it.
Old Aug 29, 2010 | 03:24 PM
the drive gear on the dissy doesnt have any play. I have installed a new pickup coil, so thats the reason why the dissy got removed. I would have no idea if the oil pump/shaft is like stock or not. The engine is actually a rem. acdelco engine. I found the stamp on the block today. I know i cannot remove the oil shaft from the top. No magnets i have (5lbs) will pull it out. So what now? Remove oil pan?
Fronzizzle
Mar 18, 2019 08:29 PM
db057
Aug 22, 2015 08:17 PM
86IROC112
Aug 21, 2015 07:20 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
