looping powersteering hoses...
Old Aug 30, 2010 | 11:02 AM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
as title says can i loop my powersteering hoses on the steering box? my pump is shot and spraying fluid everywhere and was wondering if itll hurt anything if i loop it til i do my maual box install.... thanks
Old Aug 30, 2010 | 11:48 AM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: looping powersteering hoses...
If you have V-Belts, why not just remove that belt, and the pump?
The other belt will still operate your Alternator and water pump.
Old Aug 30, 2010 | 12:05 PM
Engine: 355
if i remove the pump i have to do something with the lines feeding into the pump, goal is to remove belt and pump but goota run lines somewhere........
Old Aug 30, 2010 | 01:23 PM
Ahhm I see. You wanted this as a fix until you get your manual box, I thought it said you were putting one in, as they dont have lines.
I dont see why looping the lines wouldn't work, just real hard to turn...
92camaro350cci
Oct 14, 2015 09:29 AM
Nervous2
Oct 8, 2015 10:53 PM
luvofjah
Sep 26, 2015 08:28 PM
Nick McCardle
Sep 10, 2015 08:36 PM
