Need to ID part on sending unit.
Old Aug 30, 2010 | 06:12 PM
fyancey's Avatar
Forgive my ignorance please..I'm putting this sending unit back together.. looks like a valve of some sort I'd like to know what this is..
and if it's worth trying to replace. Will it affect how the engine runs?
Is this an emissions thing? I'd like to just leave it alone..
Autozone and the dealer had no idea..
89 firebird formula 5.7 liter
Old Aug 31, 2010 | 01:37 PM
fyancey's Avatar
Re: Need to ID part on sending unit.
Any ideas? Anyone? I hate to put this back together and find out I needed to replace it
Old Sep 1, 2010 | 12:02 AM
Naldo's Avatar
does that line connect to a vent at the point where the sending unit lines meet up with the hard lines going to the front? I believe it is a filtered vent, and as long as its not clogged shouldnt affect anything.
i just had my tank apart and saw a similar, but not exactly the same thing. i dont have an in-tank fuel pump though.
Old Sep 1, 2010 | 12:05 AM
Naldo's Avatar
on the other hand - it could be a pickup point for the fuel vapor line that runs up to the vacuum canister feeding the purge tvs/canister control valve. again tho - if its clear its not going to make a big difference in performance to leave it or replace it
Old Sep 1, 2010 | 01:53 PM
fyancey's Avatar
Well. It's not a liquid fuel line. I know that much. I took it apart. It seems like a one way valve that if enough pressure is forced on it.. it will vent. But blocks in the opposite direction. The metal case is split around the edges and it's really going both ways right now. Not sure how to remove it completely from the sending unit. When you bend the tabs up.. a plastic piece remains firmly seated in the top of the unit. I wonder if it's a pressure relief valve of some sort.
Old Sep 1, 2010 | 02:30 PM
fyancey's Avatar
Someone replied to me from another source. Good info I guess..
Hello Floyd, The part you are talking about is called a Rollover valve. It does just what it is named. If the vehicle was to roll over upside down it closes and stops the fuel flow to the engine compartment.
Old Aug 3, 2011 | 01:59 PM
Firebat's Avatar
Is there a part number on that part? Anyone know if this is something that can be bought at an auto parts store? Mine is clogged and am going to try spraying carb cleaner in it but would prefer to install a new part.
LT1Formula
20
Nov 14, 2015 12:02 AM
355sbcTPI
Aug 19, 2015 04:38 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
