tpi runs like a carb cold
HI
I have tpi but when my car is cold and i start it i have to keep giving it the gas to hold idle or it will stall. The car runs great when warm or if i take off right away its fine. Just does not want to idle when cold without help. If i put tje ac on when from a cold start the comp drags kill the idle right away.
Is it the idle air control valve? anything else? 305 F Motor auto
THANKS!
Tommt
THANKS!
Tommt
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: tpi runs like a carb cold
check for codes
to many possibility O2, TPS, IAC, MAF
this is where I would start looking
theshackle
Mar 5, 2017 06:37 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
