89 Formula cranks wont start
Old Sep 12, 2010 | 06:16 AM
cavmedic's Avatar
Car: 89 formula 350
Engine: 350 tpi
Transmission: 700 R4
hey guys i have a 89 formula 350 tpi it has 75k miles sometimes it will crank but wont start unless i spray some starting fluid in the intake. other times it starts just fine, so far i have replace the cap and rotor coolant temp sensor and the tps, i have good fuel pressure and spark when this occurs any suggestions would be great thanks.
Old Sep 12, 2010 | 07:11 AM
stealthroc89's Avatar
Car: 1989 IROC-Z
Engine: 355, 6.0 (LQ4) soon
Axle/Gears: Borg Warner 2.77 for now
Re: 89 Formula cranks wont start
What is good spark/fuel pressure? If you have good spark and fuel pressure you should have some kind of combustion, at least a sputter. Have you messed with the timing any? Have you checked your injectors to see if thier pulsing?
Old Sep 12, 2010 | 07:19 AM
cavmedic's Avatar
Car: 89 formula 350
Engine: 350 tpi
i had my brother turn the care over the fuel pressure was 24 psi all the injectors are pulsing and i pulled all the spark plug wires off one at a time and there was spark coming from each wire, but the engine would just turn over no crank. if i take the intake hose off and spray a little starting fluid in the fires right up. i cant figure out what the problem is. some days i got out and it starts right up
Old Sep 12, 2010 | 02:48 PM
DIRTY JERZY's Avatar
Car: 89 formula 350 & 2001 ws6 ta
Engine: 350 tpi & ls1
Transmission: 700r4, t56
Axle/Gears: 9 bolt ? & 10 bolt 3:42
cap and rotor won't fix it try a rebuild of the whole distributer. I think it's a reluctor ring that cracks or something like that.
Old Sep 12, 2010 | 04:09 PM
MartysIROC's Avatar
Hey Man. If it runs on starting fluild, then its not getting fuel. Do a Ohms test on ALL the Injectors. Record the values of each. They must be within 3 ohms of each other. Good ones start around 16 to 17 ohms. One or two real bad ones with a low resistance, and the engine will not start!
Old Sep 12, 2010 | 09:12 PM
Car: 1989 IROC-Z
Your fuel pressure is pretty low, should be around 40psi.
Old Sep 13, 2010 | 11:13 AM
cavmedic's Avatar
Car: 89 formula 350
Engine: 350 tpi
thanks for all the suggestion i will check the injectors and probably get a new distributer and i stand corrected on the fuel pressure it is 42 psi while cranking
Caspar
Jun 19, 2016 11:19 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
Tonyy_z
Aug 12, 2015 07:20 AM
