Block Identification
Old Sep 14, 2010 | 07:44 PM
RStevens's Avatar
Car: 1985 Camaro Coupe.
Engine: 305, for now.
Transmission: automatic overdrive
Axle/Gears: 3.08 for now
Hello, I tried the search on here and came up empty handed. Could someone direct me to a web site to ID SBC Engines? I just traded for
a 350 and getting ready to pick up a couple more from a guy. The ID on the block, flat landing in front of the passenger side head is K0430UZA. I know they are post 87 blocks because the block isnt drilled for a manual fuel pump. I'm also confused because I assumed all post 87 SBC were equipped with roller cams after reading from David Vizards "How to rebuild SBC on a budget" Any info is appreciated. P.S. great site here with lots of info for I just purchased my first F Body in June.
Old Sep 14, 2010 | 08:00 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Block Identification
Suffix code UZA
1981 350. 165 HP, 4 bbl carb. Pickup truck or van engine with a manual transmission.
Check to see if there's a pilot bearing in the end of the crank for the tranny input shaft.
Old Sep 15, 2010 | 04:52 AM
RStevens's Avatar
It has a one piece rear main so I thought it was an 87 - later. I'm gonna have to look for some more numbers. Thanks man.
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
skinny z
Oct 5, 2015 06:23 PM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
