Hard start then stall
Old Sep 14, 2010 | 08:51 PM
usmc949803's Avatar
Car: 92 Camaro RS
Engine: 77' 350 bored 355 Holley carb
Transmission: Turbo 350
Put my new hei dist in today with plugs and wires. car ran a few times during the day. went to start before. is really hard to start then the times it does it runs for a few seconds then dies. fuel pressure is still 6psi. some thoughts fuel problem? bad ground? or.....
Old Sep 15, 2010 | 07:32 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Hard start then stall
Are you sure about where you set the initial timing?
Old Sep 15, 2010 | 09:04 AM
usmc949803's Avatar
Car: 92 Camaro RS
i marked where the vac advance was and lined up dist with 0 on dampner and rotor was pointing to number one. dropped new dist in. car started up and ran a few times during the day for up to 15 mins till i shut it down. drove it up and down driveway. chirped tires. then later on this started. hooked meter up to dist (battery term) voltage is at 11.9 and is there when engines stalls. fuel pressure is about 6psi right before carb. like i said starts 5 secs dies.
Old Sep 15, 2010 | 09:24 AM
usmc949803's Avatar
Car: 92 Camaro RS
ok so got car running after a few times. used SEAFOAM in carb through vac line last night like ive done numerous times in other cars. got smoke out and all. guessing maybe it was still pushing crap through. still getting smoke out exhaust but running steady. DUH lol
Old Sep 15, 2010 | 10:19 AM
usmc949803's Avatar
Car: 92 Camaro RS
still having prob with starting. tries to turn over but not unless i jump it. volts drop low. added another ground today.
92camaroJoe
Jul 29, 2023 07:57 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
cstrobel65
Aug 15, 2015 10:19 AM
92camaroJoe
Aug 13, 2015 06:07 AM
