fuel
Car: 1987 camaro,88 firebird
Engine: 2.8 v6,5.0 tpi
Transmission: manual
Axle/Gears: 3.47
fuel
87 2.8... mechanic said bad fuel pump. wat do i gt test to make sure? all i no is the relay.. does it just go from the relay to the pump? what do i do to test the relay?
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Pump Jump
Use a test light to see if you have power on pin A of the pump relay (orange wire).
It doesn’t matter what position the key is in.
If you don’t have power there check the inline fuse located near the battery.
If there is power there jump pin A to pin E.
Does the pump run when you do that?
Happy Racing!
My Brakes Don’t Work AT ALL When The Car Is In The Air
Happy Racing!
Car: 1984 Firebird (89 Formula Clone)
Engine: 357
Transmission: m29 T56
Axle/Gears: 3.27 9 bolt Borg Warner.
Re: Pump Jump
Happy Racing!
Happy Racing!
Axle/Gears: 3.47
Re: Pump Jump
Happy Racing!
Happy Racing!
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
